I was using "Armor All Wheel Cleaner" (http://www.armorall.com/prodcat/pages/whee...eaner_2.21.html) on my Rims... I did exactly what the direction said.. I hosed down my rims, then I sprayed the 'wheel cleaner' on and left it for 60 seconds... then used a high pressure hose to clean it. Then, as it dries up, I see white stains on my rims... can't seem to get them off... do any of you guys/gals know how to get rid of this stain?
btw.. I aint never gonna buy cleaning products for my car EVER again :mad:
https://www.sau.com.au/forums/topic/34236-no-more-wheel-cleaner-products/
Guest RedLineGTR
Before use, test on an inconspicuous area. If hazing or spots appear, discontinue use. Do not apply to brake parts or other zinc and cadmium-plated surfaces
Dont know if it comes off...but i only use Meguires Rim Cleaners there are like 3 differernt types for different types of rims aloy/crome/clear coat etc. Hope fully it isnt too serious.
Yeah, I tried Eagle 1 aluminum cleaner. It worked great, but ate away all the polished surfaces! So I had to spend another hour on the rims with good old Autosol. Problem is, my rims have aluminium sand cast surfaces and they absorb brake dust like a sponge.
btw.. I aint never gonna buy cleaning products for my car EVER again :cheers:
I know how you feel, exactly the same thing happened to me with that stuff! It eventually faded away after a while.
The Armour All product discolours aluminium, I used it on my AC Cobra rims and they went all white stained and scummy.
AutoSol is the god, but the stain my go too deep, time to send them off to be machine polished or refurbished. Laquered or un lacquered aluminium is bad new with that product.
I use Auto Glym on my wheels but hey are painted alloys not polished.
Good luck with the clean up my heart goes out to you.
I'm hoping that it will fade away...
I also used Mineral Turbintine, but with no success in removing the stains..
How long did it take b4 it started to fade away? A couple of weeks, months?
nuthin beats warm water and soap....trust me i used to b a manager of a car detailing place....we used all different products and and nuthin worked like warm soapy water...
Agreed :headspin:
I have used some Meguirs stuff but that was for chrome wheels on the inside for shows...
i have used that acid free meguiars wheel cleaner - just spray it on and wait 30sec and hose off... not too bad, but i have run out so i have been using the soapy water that i have been cleaning the car with to clean them. then after i have dried them use windex for a streak free finish...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
