Hey Kilbs, where are you located?
Vulcan Panel and Paint in Canningvale are really good, I had them fix my rear bumper after it was trolley'd in the car park at work.
Excellent work and reasonably priced too.
Don't have their business card handy but they r in the yellow pages :P
https://www.sau.com.au/forums/topic/342441-vandalised-r33/#findComment-5524125
Man that sucks :l
I found a few fridge magnets with the local police station details on it stuck to my car this morning :P
Somebody thinks your a hoon and wants to scare you, find out who it was and do a burnout on their driveway. I would.
To OP:
Use a heat gun to try soften it up as said earlier, you should be able to get most of it off and nothing abit of paint wont fix if it does go horribly wrong.
Sorry to see that sort of crap, GL.
https://www.sau.com.au/forums/topic/342441-vandalised-r33/#findComment-5525498
lol. what faggotry.
rampant rampant faggotry. sorry to hear this bro..
few things - SMELL it first.. make sure you know what you're dealing with before trying anything..
could be a number of things - my gf's swift was vandalised a few weeks back in similar fashion but with choc milk n tomato sauce n kecap manis.. lucky for me i was onto it fast n got it all off..
IF IT IS wood working glue.. you want two of the following:
a hot sunny day
a heat gun
a steam gun
a hairdryer
a plastic scraper
GLOVES
make sure you have gloves... there was this one time that i once found out that once glue heats up - it goes soft n runny.. and you can pick it off using your fingers.. but once you have it on your fingers. it's HOT. and that sucks
...so you try wipe it off..
but it's sticky. cos it's glue. and it's hot. cos it's hot.
and it spreads. then goes cold.
and it sets. cos it's glue.
so wear gloves.
https://www.sau.com.au/forums/topic/342441-vandalised-r33/#findComment-5526567
so wear gloves.
absolutely gold dude hahahaha
agreed on the method though! hope you can fix it dude!
https://www.sau.com.au/forums/topic/342441-vandalised-r33/#findComment-5527364
thats totally bogus. there are plenty of derro people around in mozzie but i thought most were closer to stirling hwy around all the appartments and the like. seen some weird people around on vic/wellington while test driving.
https://www.sau.com.au/forums/topic/342441-vandalised-r33/#findComment-5527392
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
