1st up what size pipe is the z tube? Yes I know I could simply go measure the diamater of the std V35 intake but its 12am and I cant be bothered to pull off my airbox etc
2nd I was thinking about simply going to bunnings and picking up some plumbers pipe in whatever size the z tube is and then cutting them to size
the only hard part of this will be the connecting the breather/oil vapor line to the new PVC tube, but I do have a catch can left over from my 180sx that I can probaly put to good use
https://www.sau.com.au/forums/topic/342451-iv-got-a-crazy-idea/
Measured the old stock tube that I had laying on the bench.
Inner diameter approx 74mm
Outer Diameter (inc. lip) 82mm
I am pretty sure getting them from the USA is pretty cheap?
Another "crazy" idea is to go around some wreckers and just do some measuring and see what you can come up with? Maybe a VN type commodore maybe close?
Edited by omp
There are a couple on ebay for the $60ish mark plus postage, could be around the $100 mark delivered? Postage will be slowing down around this time of year due to christmas though.
Had a look for curiosity's sake and perhaps a VS commodore V6 pipe may fit.
But I think get the proper pipe.
in all seriousness I did not know the melting point of PVC was 80 deg
this is the reason I ask these questions on here before even considoring to do them for real
I did also mentio that this was a rather crazy Idea as well in the titel fcruz3r prehaps about as good as using duct tape as bunji jump rope :D
Edited by 180 wanabe
Whats wrong with the standard intake?
I have yet to see any real results from these "bolt on 11kws with a bit of tube" things that every man and his dog is selling.
im sorry but your car will not provide enough vacume in the intake pipe to cause a restriction.
maybe is it was a 400 odd cube V8 that has a 2" intake pipe, then yeah it might help.
the piping youre thinking of will probably have a higher melting point, being that you put hot liquids down the drain at home
that said, its gonna get hotter under a bonnet than most PVC piping will handle.
I do agree with this somewhat. I have a z-tube and K&N panel (which I purchased in very good 2nd hand condition from Bee) and I have to say, "by the seat of the pants" driving there isn't much difference. But the induction sound changed and it now has a nice growl!
I did also mentio that this was a rather crazy Idea as well in the titel fcruz3r prehaps about as good as using duct tape as bunji jump rope :laugh:
was jus takin the piss at ya :P
but in all seriousness, had a mate drag running his mitsu mirage that had a pvc storm pipe elbow stick out of a cut out portion on his bumper to funnel cold air to the open pod filter ...looked ugly as but did the trick
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
