Fek, that is one hot car.
The FG's are near to perfection in my book. Just the right amount of aggression and class. HSVs are too boofy for my liking and the BAs can be a bit underdone.
So, so hot. Awesome colour, too.
Grats :yes:
Grats :yes:
i agree for the sedans but not for the utes. i don't like the FG utes anywhere near as much as with the holdens or the BA/BF utes.
Grats :yes:
Nice
Thanks guys,
Goes like a dream!!! absolutely loving it..:worship:
I sort of agree but I guess I personally forgive Ford for a slight aesthetic problem with the utes as it's done from a "Function over Form" perspective. I like cars to work properly as well as look good. Unfortunately the bland rear end and the big gap between the cabin and tray is a necessary evil.
Tho have you seen an FG with an alloy flat try? Very, very tough.
Not a fan of the colour (or wheels), but I love the concept of the following:
yeah the trayback falcon utes in the BA were tough. haven't seen an FG though (that pic looks like it's a BA/BF)
Haven't seen one either, It would be so hard to drive in the wet... no weight at all. fcking scary...
  • 2 years later...
Sorry to bump an old thread, just wondering how you're finding the F6 Ute after a few years?
Need a ute for work and narrowed it down to either a E3 Maloo R8 or and FG F6 much like yours.
Drove the Maloo yesterday and was impressed with the handling and the noise, but I think I miss boost a little too much!
How do you find the handling with the live rear axle?
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
