Silly question.
And an equally silly first response.
Depends on the motor condition. Have you had it checked?
Depends on the tune/tuner. Have you had it looked into by a reputable tuner?
Depends on supporting mods. Are all the supporting mods in place?
https://www.sau.com.au/forums/topic/342663-rb26-psi/#findComment-5527133
Silly question.
Depends how much he really cares if his compressor wheels find their way through the intercooler lol
https://www.sau.com.au/forums/topic/342663-rb26-psi/#findComment-5527262
I thought I read somewhere that only the 34 N1 or something weren't ceramic....or moreso, that at least one of the "N1" turbos wasn't steel compressor AND exhaust.
No N1's are all steel wheeled, you might be thinking about standard turbos.
https://www.sau.com.au/forums/topic/342663-rb26-psi/#findComment-5527304
Depends on all the above,
if you have fuel system to support more than 14psi then i wouldnt be pushing much past 18psi
on a built motor and supporting fuel system you might get away with 20psi high boost.
just make sure that your AFR are correct for the boost level you're running, there is no point running 18psi if you cant give the motor enough fuel for that amount of air
https://www.sau.com.au/forums/topic/342663-rb26-psi/#findComment-5527553
Silly question.
if it wasnt standard i would have noted the modifications.
the motor is in good condition, its only done 68,000klms.
ive checked compression, valve clearances, spring pressure, injector pulse, you name it ive checked it.
i want answers like the first one, i was looking for people telling me how much they were running on their RB26's not people telling me what they think i should be running.
https://www.sau.com.au/forums/topic/342663-rb26-psi/#findComment-5528481
its running 15psi standard without the restrictor. theres is no issues with the air/fuel ratio.
i just want to know how much psi people are running on their own rb26s.
https://www.sau.com.au/forums/topic/342663-rb26-psi/#findComment-5528484
A answer of "XX" psi is a silly and dangerous one mate.
So are you going to get it tuned?
If not, then i wouldn't be running 18psi at all.
https://www.sau.com.au/forums/topic/342663-rb26-psi/#findComment-5528493
i probly will get it tuned but,
im not going to jack up the boost on mine. i dont even have a boost controller. im trying to keep it fairly standard in the hope that maybe 10 or 15 years down the track it might be worth a little bit.
i just want to know what people are running, and what people have run that has caused problems.
https://www.sau.com.au/forums/topic/342663-rb26-psi/#findComment-5528593
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
