Can anyone offer a "before" and "after" testimonial on the effectiveness of Extrude Honing a cast iron stock exhaust manifold?
I have found two places on the net which do extrude honing (abrasive polishing of the inside of the manifold to improve gas flow), one is in Sydney (Abrasive Flow Industries) the other in Victoria (Specialised Power Porting). Has anyone used either of them?
https://www.sau.com.au/forums/topic/342729-extrude-honing/
I have an extrude honed HKS manifold.
It flows more evenly pre to post but unless they create a new decimal scale of increments along a bees dick I don't think it will prove to be great value versus other modifications for a light to moderately modified car.
https://www.sau.com.au/forums/topic/342729-extrude-honing/#findComment-5528005
Thanks for the comments. My stainless steel "high flow" manifold has once again developed a couple of cracks (nothing too noticeable as yet but it sure won't get better..) and before facing down the changeover job back to the stock manifold I thought perhaps extrude honing it might minimise the loss of response while achieving reliability.
As for prices, the place in Vic quoted me $550 last February but is now $660. The place in Sydney quoted $1500! Are there really that many people wanting this mod that they can demand these bucks? A guy at Just Jap told me the process cost him just $200 a couple of years ago.
https://www.sau.com.au/forums/topic/342729-extrude-honing/#findComment-5528461
Don't get me wrong extrude honing is very cool, it feels like oily glass when it is finished but trying to measure a substantial difference is next to impossible for most of us. Perhaps on a race team budget it would be worthwhile to sneak any incremental gain but on a heavy car like the stagea it would be money better put towards an RB30.
What turbo are you running?
$500 sounds about the money that was paid by Legend01 when he owned the manifold.
https://www.sau.com.au/forums/topic/342729-extrude-honing/#findComment-5528560
In building my RB30, I checked out extrude honing and spoke to one company that provides this sort of service.
Found out that they commenced the job with a fair bit of die grinder work and then pump the abrasive medium through the gas passages to finish off.
I looked at the stock manifold and then took to it with my porting tools and abrasives. The biggest two areas needing attention were the sharp shoulders inside each primary runner, and then a pretty ugly looking collector area.
Spent probably a few hours from start to finish, lots of looking and planning, with pretty satisfactory looking results and much reduced turbulance inducing edges + a fair go at port matching to the head. I followed the same principle in doing a basic porting job on the head. Bugger all material removed, but a decent amount of time spent smoothing sharp edges and blending curves.
I'll have no idea if it improved things because no direct before/after tests were possible and I didn't put it on a flow bench. But I know my approach wasn't that far from the job being enquired about, and the job didn't look or feel much different from a few heads I've seen done by reputable porting services.
I'd agree with Wolverine about the manifold unless you have the time, inclination and gear to do it yourself. And even at $500 you're a good way towards paying for a 6boost or ETM.
https://www.sau.com.au/forums/topic/342729-extrude-honing/#findComment-5529181
I guess what I was asking was whether anyone actually felt an appreciable difference in the performance of the car after extrude honing the manifold.
I have noticed the sharp edges on the shoulders of the bends inside the manifold and that's what made me wonder if extrude honing might make a significant difference. Rather than paying at least $700 (incl freight) for extrude honing though, I might invest in a flexible drive and have a go at smoothing those edges myself before re-installing the stock manifold.
The engine is in a fairly mild state of modification: big exhaust and s.s. manifold (which cracked, was repaired, straightened and has now cracked again after a supersprint at EC) big Blitz front intercooler, HKS turbo (but don't know what kind as it came with the car) but it's in the standard position and set for a maximum 1 bar of boost, Splitfires and a Nistune board in the ECU. Tuning the ECU on the dyno only showed 182 rwkw but the workshop reckon it could be 10% conservative, so 200 at best.
You're right about the weight, of course, which is why spending heaps on power mods to overcome that disadvantage is pretty questionable. Having said that I really enjoy the feel of the car on the track - it will never be seriously competitive, however, and always a compromise vehicle in which I can also take my mal and my dog to the beach!
https://www.sau.com.au/forums/topic/342729-extrude-honing/#findComment-5529356
Honestly for those mods and power i don't really think there is much point in spending $700.
I mean you have free power - boost. Another 2psi would give you more gains the porting a stocker manifold. I think stock manifold wise you'll be quite fine.
Also the time/labour to fit/refit etc.
https://www.sau.com.au/forums/topic/342729-extrude-honing/#findComment-5529367
^^^ as above -turn up the boost. Actually maybe you need to take a trip up to Sydney and get someone like Yavuz at Unigroup to do a proper tune. My S1 Stagea with a GCG highflowed R33 turbo was making 245awkw at 1 bar so yours sounds a bit low. Try to find out what kind of turbo you have - maybe you need bigger injectors, a Z32afm and maybe a better fuel pump if that hasn't already been upgraded. As has been said before the stock exhaust manifold is good for 300kw, stainless high rises are good for nothing except cracking. Your stock manifod will be fine although you may need some kind of spacer depending on the turbo.
https://www.sau.com.au/forums/topic/342729-extrude-honing/#findComment-5530081
I very much appreciate all the thoughts and advice provided on the extrude honing option. Certainly the boost is still modest and I'm running a stock airflow meter, so some opportunities there but I'm amazed at some of the rkw figures you are all quoting - clearly I have a lot to learn about the mod's available.
Before removing the cracked s.s. manifold and refitting the stock one I will now have a go at porting it, with the help of pics taken of a similar exercise by Dale.
https://www.sau.com.au/forums/topic/342729-extrude-honing/#findComment-5531524
i would not play with the std manifold much they are prone to cracking as it is... could end up with a real expensive paperweight.
https://www.sau.com.au/forums/topic/342729-extrude-honing/#findComment-5531634
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
