  • Replies 109
Posted Images
was there at 5... im there at 5 most days.. just drop me a txt tommorow b4 5 tommorow if im in the city i will call you and meet to give coin
Sorry mate, I start at 6am, so long gone by 5pm :) The other option is to drop into an ANZ Branch, I think they close at 4:30pm.
i think i will go to the anz, i dont leave work till 4.30 n then it takes a half hour to get into the city
No worries, just go the the ANZ with the account details on the first post, and they'll transfer the money :P
Tested out the R34 around Nurburgring over the weekend. Everything is looking good at our end.
The car handles really well. I've set the Easy setting the same as Medium so that everyone runs at a similar setting.
We wouldn't want someone to pick easy and leave everyone for dead.
You'll have the ability to turn the traction control to off/low/medium/high while driving.
There are 4 view settings -
Default view - Inside the car looking out the dash
Bonnet view - looking over the bonnet
Front view - Viewing from the front with none of your car in site
Tail cam (hard to drive as the motion doesn't compliment the visual movement of the car doesn't work well together
Easy/Medium - Medium steering and braking help - High traction control - Auto resumes in 8 secs after leaving the gear shifter alone
Hard - No steering or braking help - medium traction - Auto resumes in 30 secs after leaving the gear shifter alone
The cars have a clutch but the software is set on autoclutch to prevent everyone from stalling when they crash. You can drop the clutch anytime and it will work as a normal clutch would.
If you select Easy/Medium the cars will start in auto, when you touch the sequential shifter it will change to manual. If you leave the gears alone for 8 secs it will revert back to auto
If you select Hard you will need to put the car in gear at the start - it will then run in auto.
If you touch the gears it will change to manual and stay in manual. If you leave the shifter alone for longer than 30sec it will revert back to auto again.
So there you go.
Tom Kennedy
SimWorld Entertainment
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
