  • Replies 96
Posted Images
http://maps.google.com/maps?f=d&source...mp;t=h&z=10
Full path for those interested, including the meetup point at Albion Park (along the side of the road there like last time)
hey owen. i tagged along the last cruise up to the pie shop.. u guyz gonna meet up at ap maccas again or along side the school??
probably a bit of both; as it gets closer i'll post up a semi-meet at maccas, but predominantly will be at the school. don't want those cops rocking up again :)
yea true that
Sounds good, anyone from the blacktown area want to meet up at wood croft maccas an hour before hand?
let me know how you go with this. I am in greystanes so if you find yourself alone ill meet ya somewhere close to make the trip down
Rockslide On Macquarie Pass this morning.
It affects westbound (ie uphill) traffic.
Plan B (if roadworks are still ongoing in 2 weeks time) would need to be...
* Continue through Albion Park onto Terry St > Jamberoo Rd (southbound)
* Just before coming into Jamberoo > turn right onto Jamberoo Mountain Rd > Robertson Pie Shop at the top.
If Plan B is implemented, drivers just need to be careful of narrow sections going up through Jamberoo Pass :)
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
