The NSW RTA is proposing changes to the current registration system for modified vehicles. These changes will mean that the majority of modified vehicles will be classified as individually constructed and will have to comply with the ADR's current on the day that it goes for registration. Please follow the link below and sign the petition to assist us in taking the fight to the NSW Transport Minister.
http://www.gopetition.com/online/37707.html
Lifted this off another forum. Would be worth spreading around to whatever forums you guys go to. Under this law it would make it near impossible to modify and older vehicle.
A car should comply with ADRs if it wants to be registered, but this would require a car from the 80s to comply with 2010 ADRs to be considered 'roadworthy'.
signing this petition will only give them numbers of how many people have modified cars, it wont actually change their minds. i was listening to the process of how a bill is passed. at no point do they say "are there any petitions against this legislation?". they read the bill and its positive effects, what it intends to do and as soon as they say "emissions this, emissions that", it will get passed. dont forget these are people who get driven around and/or have a car that is no more than 1 year old.
what you SHOULD do is get an engineers certificate for a modified car that fits in this category before this is passed, because if this bit of legislation comes in, the next step is to make it harder for older cars to obtain one.
Signing does help... especially when it comes close to state elections and what not and number matter.
The gaming R18+ classification is finally going to be actioned after parliament acknowledged a petition.
So, where are the proposed rule changes listed? There's no link to where the details are in the petition, and I'd personally like to see them to see what we're up against.
+1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
