  • Replies 181
Might not hurt to post up a list of whats left bro, just copy paste your original list minus the shit sold you've people are too lazy to read through whole thread :P
Free bump.
Edited by Nee-san
Free bump.
Cheers mate, very true
front pipes $100
sunvisors $20 each
interior mirror $20: SOLD
interior lights $40
dash loom $100
interior carpet $70
boot carpet $60: SOLD
heaterbox/ all under dash make an offer: SOLD
rb26 cam/timing belt cover $70
speedo 140,xxxk's $50
brake calipers x 2, $100
intercooler mesh $30
trust pod filters x 2, $80
monster tacho with shift light $50: SOLD
steering wheel $50
GTR fuel pump exc. working order $90
glovebox $30: SOLD
HICAS computer $50 plus have other little computers from throughout the car
have ALL windows except drivers side
rear wiper + motor $40
boot release with fuel flap popper $40
side mirrors $50 each
bonnet squirters $20 pair
bonnet heatshield $60
A,B,C pillars
clutch master $40: SOLD
brake booster $60
accelorator with cable $50 brake and clutch pedals $30 each
steering rack $150: SOLD
metal plate that goes inbetween rear seat and boot $60: SOLD
windscreen wipers $30 pair: SOLD
window wiper motor $40
overflow and washer bottles
kickpanels $20 each
assorted cooler piping from gtr $50
wheelnuts $25
seatbelts
rearseat in mint condition $150
boot rubber seal perfect cond. $40
drivers door window switch $50
rb20 crossover piping $40
turbo timer exc. working order $30: SOLD
handbrake $30
random 8 inch subwoofer never been used $20
Drivers side reverse light: SOLD
O.N.O. on pretty much everything
The problem with posting this list is that there is wayyyyyyyyyyyyyyyy more stuff than this u just gotta ask and i can hook u up.
The entire underside of the car is there except the front calipers, parting out the rear end diff etc.
PM me i'm on here every day.
Some photo's on page 3, i will get more photo's up soon. Cheers
front pipes $80
sunvisors SOLD
interior lights $30
dash loom $100
interior carpet $70
rb26 cam/timing belt cover $60
speedo 140,xxxk's $40
rear end, brakes all there $800
intercooler mesh $20
trust pod filters x 2, $70
steering wheel $40
GTR fuel pump exc. working order $70
glovebox $30: SOLD
boot release with fuel flap popper $20
side mirrors $40 each
bonnet squirters $20 SOLD
A,B,C pillars
brake booster $40
window wiper motor $30
kickpanels $20 each
cooler piping one side $20
wheelnuts full set $10
rear passenger seatbelt $20
rb20 crossover piping $30
handbrake $30
door sills that say skyline $20 each
wheel well cover from in the boot $30
gearbox mount $50
interior door handles $5 each
car loom
1 N1 vent need respray. offers
Front cradle is there still, hubs etc.
final drive shaft
centre console no lid $30
rear bar, haggard suit drift pig
rear boot trim
GT badges $10 each
fuel flap $10
space saver wheel
C Spanners x 2
tailshaft
interior door wiring
wiring from throughout the car just ask
bonnet hinges may be a little bent $20 for both sides
passenger door rubber no rips or leaks $30
Prices adjusted and more stuff added! Pictures for items on request. If there's something u want that u can't see here just PM me, i have heaps more. Everything is O.N.O. and must go. Offers welcome.
Cheers :thumbsup:
front pipes $80
sunvisors SOLD
interior lights $30
dash loom $100
interior carpet $70
steering wheel $40
glovebox $30: SOLD
A,B,C pillars
brake booster $40
kickpanels $20 each
handbrake $30
gearbox mount $50
car loom
final drive shaft
rear boot trim
GT badges $10 each
fuel flap $10
space saver wheel
C Spanners x 2
tailshaft
Cheers :thumbsup:
:yes:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
