  • Replies 181
Photo's on previous page
front pipes $60
sunvisors SOLD
interior mirror $20: SOLD
interior lights $20
dash loom $60
interior carpet $40
boot carpet $60: SOLD
heaterbox/ all under dash make an offer: SOLD
rb26 cam/timing belt cover SOLD
speedo 140,xxxk's $30
rear end, brakes etc. everything there $700 Buyer organises postage
intercooler mesh SOLD
trust pod filters x 2, $50
monster tacho with shift light $50: SOLD
steering wheel (310mm) $30
GTR fuel pump exc. working order SOLD
glovebox $30: SOLD
HICAS computer $40 plus have other little computers from throughout the car
have ALL windows except drivers side
rear wiper + motor $30
boot release with fuel flap popper SOLD
side mirrors $30 each
bonnet squirters $20 SOLD
bonnet heatshield $40
A,B,C pillars
clutch master $40: SOLD
brake booster SOLD
clutch slave cylinder $30
accelorator with cable $30 brake and clutch pedals $20 each
steering rack $150: SOLD
metal plate that goes inbetween rear seat and boot $60: SOLD
windscreen wipers $30 pair: SOLD
window wiper motor $30: SOLD
overflow and washer bottles $15 each
kickpanels $20 each
cooler piping one side $20
wheelnuts full set SOLD
rear passenger seatbelt $20
rearseat in mint condition SOLD
boot rubber seal perfect cond. $20
drivers door window/mirror control $40
rb20 crossover piping $20
turbo timer exc. working order $30: SOLD
handbrake $20
random 8 inch subwoofer never been used $10
Drivers side reverse light: SOLD
door sills that say skyline $20 each
timber wheel well cover $30
gearbox mount $50
interior door handles $5 each
car loom
1 N1 vent need respray. SOLD
Front cradle is there still, hubs etc.
input shaft $50
centre console no lid $30
rear bar, haggard suit drift pig. SOLD
rear boot trim
GT badges $10 each
fuel flap $10
space saver wheel $20
C Spanners x 2 $30
tailshaft $70
interior door wiring
wiring from throughout the car just ask
bonnet hinges may be a little bent $20 for both sides
passenger door rubber no rips or leaks $30
battery clamp $10
engine mount $10
upper control arms $50
left and right cv with knuckles $80 a side
rear pod/ side skirt SOLD
Front Diff???? ta
PM coming ur way
Speedo cluster and both GT badges SOLD :thumbsup:
Also whoever was asking about top radiator mounts (can't remember who) i do have them. found them this morning :cheers:
front pipes $60
sunvisors SOLD
interior lights $20
dash loom $60
interior carpet $40
speedo 140,xxxk's $30 SOLD
rear end, brakes etc. everything there $700 Buyer organises postage SOLD
glovebox $30: SOLD
A,B,C pillars
brake booster SOLD
overflow and washer bottles $15 each overflow SOLD washer available still
kickpanels $20 each
handbrake $20
timber wheel well cover $30 SOLD
gearbox mount $50
car loom
input shaft $50 SOLD
rear boot trim SOLD
GT badges $10 each SOLD
fuel flap $10
space saver wheel $20 SOLD
C Spanners x 2 $30
tailshaft $70
battery clamp $10
engine mount $10
left and right cv with knuckles $80 a side SOLD
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
