actually erin I was having a similar problem with mine a while ago couldn't figure out what it was. At the top of third full throttle it was as if it was misfiring. Never did figure out what it was. Still has that screaming sound though. Meh I'll get it fixed eventually.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Charly, I'll let you know what's wrong with mine. I'm hoping it's somehting simple like the fuel being changed. My car never liked running on ultimate in the first place. But i thought I'd try it again. Someone did mention water being in the fuel? or the TPS being sticky. It seems to be ok on WOT, it's just when you are cruising along that it chucks a spaz. It's really annoying me. Feels like I'm actually driving a tractor now.
erin,
my 33's got nothing on my old ca18det silvia for faults. That thing was fu(ked as. It would stall if I ran the aircon. Yes stall driving along at 60kph. I only had it for 10 months and the list of stuff that screwed up on that car was as long as my arm.
My favorite was when the sunroof got jammed open when it was pouring. Sooooo not funny.
I figured the car stuttering thing was my clutch going. might have just been some dodgy fuel as there is nothing wrong with my clutch.
it's been ages since I got on here and whored. The only reason I'm on here is that I really can't be bothered doing any work and I have to wait until at least 6pm before leaving work.
On the upside all the stock I was waiting on has come in this week. Woot.
Sinbad stalls at sets of lights when coming to a stop. The revs just drop and keep dropping till it's stalled.
Somethings seriously wrong here.
:confused: Mine had that problem but I had the stock ecu and a (totally rad sounding) bov with an extremley loose and not adjustable spring. An adjustable plumback one that might I add sounds about 100x less cool fixed that problem.
I really must wind out that spring sometime.
just a question, does this happen when you have the aircon off? or all the time?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
