*grabs Laurns legs so that she doesnt fly off and bounces off the other side of the rings ropes and uses them to fling both himself and Laurn high in the air, destination on the way down looks like charly's prone body*
BOOOOOOOOOOOOOOOOOOOOOOONNNNNNNNNNNNNNNNNNZZZZZZZZZZZZZZZZAAAAAAAAAAAAAAAAAAAAAI
IIIIIIIIIIIIIIIIIIIIIIIIIIIIII!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
at the last moment I roll out of the way and unbeknowns to the two hurtling toward the ground this is no ordinary ring. The floor is actually concrete. With a thunderous thud they both hit the cold hard concrete breaking most of their bones. Many months of painful intensive physical therapy now await them both.
yeah what's wrong with you cootha is on the southside I live right next to it.
