  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hi Erin just got ya email :)
House is great :thumbsup: just discovering that im a pretty expensive person to maintain haha ;)
Mum's going away for the next two weeks to stay at my sisters house while they are in Sydney. So I'm gonna be home alone! I dont like the thought. Having to do my washing.. Do my own dishes... Cook my own food.
Hold me. I'm scared.
LOL Erin :grouphug:
Ive had to do my own washing since i was taller enough to reach the washing machine :thumbsup: I used to hate it when my i got my folks place to myself - cos it was so big n lonely. This house is a bit smaller and doesnt feel so lonely :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
