  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Jason - u a whore, pffttt lets see where you stand on the Whore List:
User Name Posts
chaos 5719
Ska 4356
BelGarion 3681
predator 2879
Genesis® 2674
Nexus9 2577
strutto 2541
Lazy-Bastard 2392
SmoothLine 2214
Charly 1661
Eug 1541
TeamKrazy 1493
NA_R33 1374
NismoGirl 1325
jaqule 1253
owned 1173
Nismo_Boy 1091
PlATiuM 980
FYN33 980
rb25 735
EVO83 700
mindflux 650
wados 621
GTS-t VSPEC 563
Oz 562
MJ 520
jlnewton 502
Squizz 486
Nizmo 454
666DAN 428
33NIZ 408
rb26dett 351
twoquik 333
MM2death 238
CGB_R32 207
knore 207
krawler 182
Zoix 141
sileighty 126
R33Steve 107
cLoWn 104
Shane 98
stuntgirl 90
NFAA32 81
Yotis 67
Mud 65
ImpulR33R 50
Skyrine-Dave 45
Rasi 44
GOR33 41
CalaisT3RBO 41
kryz 38
pimpspec 36
Ska2 31
uneekwahn 29
sweetr33 27
R33 GIRLY 24
ARKAD 23
Nizman 20
Spooks_Skyline 18
nismoman18 17
.75 degrees sideways 17
51jay 14
brakeshoe 13
V8skylineMAN 13
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
