  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Jason - u a whore, pffttt lets see where you stand on the Whore List:
User Name Posts
chaos 5719
Ska 4356
BelGarion 3681
predator 2879
Genesis® 2674
Nexus9 2577
strutto 2541
Lazy-Bastard 2392
SmoothLine 2214
Charly 1661
Eug 1541
TeamKrazy 1493
NA_R33 1374
NismoGirl 1325
jaqule 1253
owned 1173
Nismo_Boy 1091
PlATiuM 980
FYN33 980
rb25 735
EVO83 700
mindflux 650
wados 621
GTS-t VSPEC 563
Oz 562
MJ 520
jlnewton 502
Squizz 486
Nizmo 454
666DAN 428
33NIZ 408
rb26dett 351
twoquik 333
MM2death 238
CGB_R32 207
knore 207
krawler 182
Zoix 141
sileighty 126
R33Steve 107
cLoWn 104
Shane 98
stuntgirl 90
NFAA32 81
Yotis 67
Mud 65
ImpulR33R 50
Skyrine-Dave 45
Rasi 44
GOR33 41
CalaisT3RBO 41
kryz 38
pimpspec 36
Ska2 31
uneekwahn 29
sweetr33 27
R33 GIRLY 24
ARKAD 23
Nizman 20
Spooks_Skyline 18
nismoman18 17
.75 degrees sideways 17
51jay 14
brakeshoe 13
V8skylineMAN 13
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
