I do sunshine coast to tweed heads, plus a lot of stuff out west...
Noosa, Tweed, Burleigh, Mooloolaba, Dalby, Warwick, Toowoomba, Stanthorpe, Surfers, Brisbane (north and south, dur), Caboolture, Morayfield, Redcliffe, Caloundra, Dinmore, urgh far too many places to list.
Some weeks I hit the 1000k mark :D I've done 62,000k in my van and its just hit the 2 year mark. I'm not even a bloody delivery driver! :P
hahahahahahaha hey andrew u think that a lot the ute I have hase got 140,000 km on the clock & its a 7/02 :D lmao
yeah 1000km mark is easy I do 300+ every day
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
How can you drive soo much for your job, then get in a car and enjoy driving on the weekends?
When i used to work in the city, I used to bus it to and fro and I used to look soo forward to driving my car on the weekends.. Now it's like.. do I have to get into it again?!2
hay Ben I think there is a cruise tonight , but I am broke after the intercooloer today , if you could sapre a little cash I will come get you.?? I need to show this off!!
lol easy erin when the car is going its easy any way its a bitsamissen I drive at work lol not a nissan :P as some ones sig says "COME ALIVE COME & DRIVE A NISSAN" + how could I miss out on all the fun
Yeah, but I've got to try and fit work in around all my driving! Thats just driving to GET to the job, not including the job itself!
For a while there I was using a tank of fuel a day :P Thank christ some of the further out ones (ie: stanthorpe) havent broken down in a while, I'm sick of driving
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
