  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
dOING WORk at the moment (typing in caps sorry)
I'll just have it so I can challenge the maintenance manager when he's trying to beat his wifes score :)
They've all got XP and I've got Win98. Sucks to be me!
lol well like I said I will swap ya u can come take my place here being sick & I will go to work sounds fair to me :(
hahahaha challenge the maintenance manager sure sure :D
how come ur the only one with 98??? thats not fair :(
cAUSE THIS place sucks?
My computer sitll works so theres no point replacing it. Apparently. Even though I have a hell of a time with programmes and databases because I've got a crappy old programme that doesn't support most of the functions of xp. But it doens't matter. My computer's not broken!
Yes I am bitter and twisted.
How can I break my computer?
My typing also sucks.. obviously. Look at the errors in that last post!
hahahahaha I think it may be because ur wanting to be some were else right erin :)
if ya want to kill the computer I still got a virus on the computer that simtext has found & awaiting me to get ride of it I could always send it your way its one of thoes horsey ones lol :jk:
BOO!
so whats every one been upto this week ????
work, drifting at movieworld work
Woohoo! Andrew just helped me install games on my comptuer. They hadn't installed them. But I found the win98 cd and got andrew to show me how to install them :)
It's users like you that made me the bitter nazi-like twisted hard ass network admin i am today :D NO ONE on my network can install anything, but me mUAuauaU uA UAUhAha hH AH AH AH h H AHAH H AH AH h Ah AH aH !!
I have had to replace several PC's here that have had a cup of coffee "accidentally" knocked over onto :(
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
