  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
That is some sweetass fun out there on the track, good time to see how far you can push your driving skills in a relitively safe enviroment, atleast a legal one! Note to self get some tyres with grip !
hehe Adrian,
remember this
"14.489 @ 103MPH
2.998 60Ft :D go the wheel spin"
my 1/4 time with bald tyres on the 28th of July
Went back with new tyres a month later on the 25th August and got this time......
13.761 @ 104mph and a 60 foot of 2.2seconds
It is true that every 10th saved in the first 60foot = 2 tenths off your time at the end :)
Oh great time Erin :P
