  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey Josh saw you in a calendar :rolleyes:
On a serious note, I was on the harvey norman tv add!! HAHA!
I even made me a profile site thingo, damn the ladies must love my u88er net skills. http://www.myspace.com/index.cfm?fuseactio...=20041201232325
Still on the gold coast, josh was wittingly trying to defame me for running into a traffic island bout 8 mths ago, most people call me island boy because of that fact :rolleyes:
ahh so your not living at bribie..
You only have 3 freinds :rolleyes: how much did you have to pay them!! :D
Oh man you really need a better pic dude :throwup: :P!!!!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
