  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
who wants to update my pos 32 pages?
tasks: resize pics, add words over pics, cut'n'paste bits and pieces from the previous html templates, must NOT use any windows (1.0 to 2003, OS/2 with WIN-OS2 is allowed) as I dont want to run dos2unix shit over crappy dumbass CRLF txt, fonts required are actually in solaris.
pay: $0, or whatever I find useless in my garage.
pre-req: can build a pc box to run solaris x86, or mac to run linux. :(
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
