  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
- Lincoln and Kennedy were both killed on a Friday.- Both were killed in the presence of their wives.- Both were shot from behind and in the head.- Both assassins were killed before being brought to trial.
Like all insects, ants have six legs. Each leg has three joints. The legs of the ant are very strong so they can run very quickly. If a man could run as fast for his size as an ant can, he could run as fast as a racehorse. Ants can lift 20 times their own body weight. An ant brain has about 250 000 brain cells. A human brain has 10,000 million so a colony of 40,000 ants has collectively the same size brain as a human.
The average life expectancy of an ant is 45-60 days. Ants use their antenae not only for touch, but also for their sense of smell. The head of the ant has a pair of large, strong jaws. The jaws open and shut sideways like a pair of scissors. Adult ants cannot chew and swallow solid food. Instead they swallow the juice which they squeeze from pieces of food. They throw away the dry part that is left over. The ant has two eyes, each eye is made of many smaller eyes.
They are called compound eyes. The abdomen of the ant contains two stomachs. One stomach holds the food for itself and second stomach is for food to be shared with other ants. Like all insects, the outside of their body is covered with a hard armour this is called the exoskeleton. Ants have four distinct growing stages, the egg, larva, pupa and the adult. Biologists classify ants as a special group of wasps. (Hymenoptera Formicidae) There are over 10000 known species of ants. Each ant colony has at least one or more queens.
The job of the queen is to lay eggs which the worker ants look after. Worker ants are sterile, they look for food, look after the young, and defend the nest from unwanted visitors. Ants are clean and tidy insects. Some worker ants are given the job of taking the rubbish from the nest and putting it outside in a special rubbish dump! Each colony of ants has its own smell. In this way, intruders can be recognized immediately. Many ants such as the common Red species have a sting which they use to defend their nest.
The common Black Ants and Wood Ants have no sting, but they can squirt a spray of formic acid. Some birds put ants in their feathers because the ants squirt formic acid which gets rid of the parasites. The Slave-Maker Ant (Polyergus Rufescens) raids the nests of other ants and steals their pupae. When these new ants hatch,they work as slaves within the colony. The worker ants keep the eggs and larvae in different groups according to ages.
At night the worker ants move the eggs and larvae deep into the nest to protect them from the cold. During the daytime, the worker ants move the eggs and larvae of the colony to the top of the nest so that they can be warmer. If a worker ant has found a good source for food, it leaves a trail of scent so that the other ants in the colony can find the food. Army Ants are nomadic and they are always moving. They carry their larvae and their eggs with them in a long column.
The Army Ant (Ecitron Burchelli) of South America, can have as many as 700,000 members in its colony. The Leaf Cutter Ants are farmers. They cut out pieces of leaves which they take back to their nests. They chew them into a pulp and a special fungus grows it. Ants cannot digest leaves because they cannot digest cellulose. Many people think ants are a pest but I like them. To stop them coming into my kitchen I put some sugar outside. They they have so much to eat that they are not interested in coming into my kitchen.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
