If you take any number between 1 & 9 and multipy them by 9 the sum of the two numbers will always be 9
(ex: 7 X 9 = 63 ; 6 + 3 = 9)
btw if you are really mathematically inclined you will know why I have chosen Nexus9 for my name, I am such a geek
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
In 1970, an Arizona lawyer named Russel H. Ansie filed a $100,000 law
suit against God. He won because the defendant never showed up in court.
He is still waiting to be paid and accrues 10% interest per annum
The 'y' in signs reading "ye olde.." is properly pronounced with a 'th' sound, not 'y'. The "th" sound does not exist in Latin, so ancient Roman occupied (present day) England use the rune "thorn" to represent "th" sounds. With the advent of the printing press the character from the Roman alphabet which closest resembled thorn was the lower case "y".
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
