You better watch out
You better not cry
You better not pout I'm telling you why.
Santa claus is coming to town.
He's making a list
And checkin it twice
He's goin to find out who's norti and nice
He sees you when your sleepin
He knows when your awake
He knows if you've been bad or good so be good for goodness sake
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cream, negative... Condensed milk, yum... Pineapple, bat food... Passionfruit, bat food... Lemon, only with tequila... Water, OK I spose... Milk, yum... Flour, sounds kinda gay, like flower, but OK I spose... Eggs, come from chicken bum - negative...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
