  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
*sigh*
This is why I'll always use a mechanic. Andrew's pulled his car apart to get the cam reground and he's just finished putting it back together.
He's told me just before that it's now running really hot and he's not quite sure what's wrong with it. He's meant to be getting his new ball joints put in tomorrow and the steering rack.
*sigh* How come men always have to fiddle?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
