  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Done
why the fark that guy decided he would cross a racing track to get to the other side whilst a race is on I have no idea?????
not only by the look of the clip did he kill him self but looks like he killed the driver of the car too
man at lest it would of been quick for him :( would hate to be the driver if he did live how could u live with that
QUOTE=Nexus9]Done
