  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeh moite, she's got Pre-Pollution 308 Engine 5 litre, Bored out 30 thou, L34 rods and pistons, Crane camshaft and lifters, New rockers, Modified Yella Terra heads, Edelbrock inlet manifold, High volume oil pump, Holley 650 double pumper carby, Motor fully balanced and blue printed, Turbo 400 transmission, 3000rpm high stall converter, Stage 2 shift kit, B & M shifter, LSD differential.
So what your saying is it's loud, uses lots of petrol, but it's not very fast...
Correct?
hey paul,
josh has it all wrong.  It was a party that I left the lan nite for.  And then the party was lame. But I've discovered that my car actually drives better with four barley legal drunken screaming girls in it at 2am on sundays.  Really.
Barley legal teens complete that " P plater" hoon skyline look!
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
