er..maybe .. it will have a fair few photos. I am planning on it being fully dynamic back end content, mysql database, etc - but to start with to get it up i might just use flat html.
I am going to put a whole bunch of tutorials up for all the stuff i am doing, such as changing the brakes to mspec, compliancing, etc.. eventually the manual conversion, and engine drop in, lada.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
mate's cable tv box and cable modem got lightning striked a while ago..
it also scrooed up the pc onboard ethernet and mobo..
definitely turn things off and unplug
*strutto liked to be probed by dictionary.com* :P
that requires tools... even power tools..
oh well, if all my equipment gets blow up and / or myself.. I'll just sue TPG saying that they had a "duty of care" to inform me that lightning was dangerous, and come over and disconnect my internet and all appliances for me.. and that even though I am the stupid one, its their fault that I am stupid.. I will walk away with millions.
I hears its the latest lawyer bullshit these days, can't go wrong..
hey, how much cutting of a stock R32 front bar do you have to do Will in your car ?? I was getting most of the front bar off yesterday, and there wasn't a hell of a lot of room in there.. Or did you go for a GTR cooler?
think i have worked out a deal on some piping for the cooler i have :P I love the internet..
back in the old days I had 600x250x75mm fine/tube and big ass endtanks fit in the front bar with a bit of cutting.. mainly lower part (and both side intakes) trim down to almost just skin.. top part near bumper reinforce bar isn't touched..
ok.. yeah, thats about the same size cooler that is to go in mine.
I was thinking of even getting a spare reinfocement, and just cutting that.. seems a waste to hack apart a perfectly good support.
Horn and things could be a problem.. about the only mod my car appears to have is crazy japanes eairhorns.. unfortunately they don't appear to be working :P
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
