  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ed dont feel so bad.. at least u don't have coolant pissed out on the ground for no reason :(
just as well I wasnt planning to drive anywhere in the pos
haha will... i thought it was all good ? what did you bust ? a heater hose ?
glad you got that cap to putt around in :P
glad you got that cap to putt around in :(
not sure yet as I didn't know coolant leaked till few hrs after short drive and saw the wet ground..and then I rather sit in the aircon room than garage.. :P
yeah the 3cyl powah was a bit of impulse buying thing but at least its a little different ;) can't wait to make it a bit faster :D
bah u should'v turn off/unplug/smash the emergency extension fone :(
it was funny at werk yesterday, idiots rang the oncall just before 12 for spastic email client related.. little do they know no one is in the office and nothing will be done till next yr :P
well the rb20 is getting fixed up (blew a coolant/heater hose) for the 3rd time. caught it before the engine went pop. hopefully i will clean it all up for the WA transport department inpection to transfer to wa plates (noooo loose the qld plates sniff) then give a few fun runs around town then put it up on jacks... it has to be finished by october 1 next year for a mates wedding. will be doing cerimonial donuts insted of confetti
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
