  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Haha there's always one :)
See ya got a CBR in ya sig ...... my housemate has a 250 ..... ive chopped it so now he's desperately saving for a bigger bike haha
Sweet, yeah the 250s are pretty good for what they are, but they're no match for the line :D My brother's 250 used to be a road bike, he ran 14.5@92mph, now he has the R6 he's done 11.0@127 :D I could kill the 250 in the car, but against the R6 I have no chance! On the 929 it's a different story though... :kick:
hehe i said i chopped a two fiddy .... nothing spesh just braggin rights over my housemate :D
cmon i have an auto ..... and im female - let me have my braggin rights .... cmon tell me im good :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
