  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Haha there's always one :)
See ya got a CBR in ya sig ...... my housemate has a 250 ..... ive chopped it so now he's desperately saving for a bigger bike haha
Sweet, yeah the 250s are pretty good for what they are, but they're no match for the line :D My brother's 250 used to be a road bike, he ran 14.5@92mph, now he has the R6 he's done 11.0@127 :D I could kill the 250 in the car, but against the R6 I have no chance! On the 929 it's a different story though... :kick:
hehe i said i chopped a two fiddy .... nothing spesh just braggin rights over my housemate :D
cmon i have an auto ..... and im female - let me have my braggin rights .... cmon tell me im good :)
