  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
  Here is the GTR driver`s description of the "race".
 I found it  on another forum:
 Quote »
  LOL...yeah thats me
  humm....race or no race.
no race but i did try steping on it once, but was suffereing serious ignition problmes so it was basically useless. everytime here hear my rev's rise, he'd hit it
  I know the guy in the civic and that car is no joke though, made 470whp
  that was also in CO, i live in Cali now and the car is running good, so maybe i'll find a 400 hp civic and have at it...lol
  hope that clears up a few things,
meh once again .. GTR owners = s0ft!
well its actually been pretty nice last couple of days.. I can even see pure bluesky outside.
I am a little hungover after last night though :rofl: there is just too many bars in melbourne to crawl through in one night!
lol..
must be madness when everybody comes back as well.. all those days without access to a computer shop! what have all those poor little goldcoast computer guys been doing with this time? nooo!
Will they be camped out? Christmas sale style?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
