  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Dont feed the cats to the rats, make chinese food out of it and sell it in a small shop on the gold coast at 500000000000% markup, people will buy anything at any price down there :P
Surprise reboots are not good!!!!!
SUPER HAPPY FUN COFFEE!
Me: what is this that I'm eating.
Chinese food store guy: Is meat.
Me: what beef, pork, lamb, chicken?
and people wonder why there aren't many cats around sunnybank or around china town :P
Reminds me of a few years back where the local newspaper drew a connection between missing cats and the local Chinese food store.
It ended up in court. Funny for the general public though.
I wanna play it again, but fear I will be pulverised into the ground by Marc if I do, hmmmmmmmmmmmmmmmmm tough choice......................
BHAHA HhAh aH AB baHa BHhAAH hAH AH H AHh AH aH HA HAHHAH H AH hah hah aaa!!
Thats an old post...
Yeap, still funny though ;)
it was something me and cy were talking about. So he went and dug up the post.
Yeah you'd be proud of me adrian, I didnt msn/phone/sms you asking for the answer like i usually do, I actually used the search thingy, was a first!! :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
