  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I know its a long shot, but my hairdresser has left where she used to work, and when i was getting my hair cut a while back she mentioned that her brother had just bought a skyline.. was wondering if anyone knew which hairdresser shes ended up at now? 'Coz the other hairdressers around here can't cut my hair for crap, and she was always coming up with funky new styles :(
her name was Jaimee? and she worked at Jon Le Court at Strathpine
lol i love your style, hope u can find her :)
Best Whoretown post ever...
Changing thread title to "QLD Matchmakers" now...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
