  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
http://www.skylinesaustralia.com/forums/sh...ead.php?t=61781
thats got all the details on the R31..
Haven't done anything to the R32 really.. still not even on the road.. changed the brakes to the 4 pot, done most of the compliance issues.. rest is pretty much stock as..
