Women do the laundry every couple of days. A man will wear every article of clothing he owns, including his surgical pants that were really hip about eight years ago, before he will do the laundry. When he is finally out of clothes, he will wear a dirty sweatsuit inside out, rent a U-Haul and take his mountain of dirty clothes to the Laundromat. Men always expect to met beautiful women at the Laundromat, but this is only a myth perpetuated by old reruns of Love American Style.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I have 10 musical devices in my puter room...
1 puter
2 metronome
3 guitar tuner
4 electric organ
5 electic piano
6 electic guitar
7 electric bass guitar
8 flute...........this one time, at band camp..........lmao
9 Yamaha FB-01 sound generator
10 Roland PR-100 digital sequencer
User Name Posts
chaos 6485
Ska 5423
BelGarion 3724
predator 3216
Nexus9 3080
strutto 3062
Genesis® 2674
Lazy-Bastard 2392
SmoothLine 2221
Charly 1838
NismoGirl 1827
Eug 1550
TeamKrazy 1493
jaqule 1423
NA_R33 1374
Nismo_Boy 1298
owned 1175
Oz 990
PlATiuM 989
FYN33 980
GTS-t VSPEC 806
rb25 735
EVO83 700
mindflux 650
wados 645
Nizmo 588
sileighty 558
Squizz 529
MJ 520
jlnewton 511
33NIZ 477
666DAN 440
rb26dett 351
V8skylineMAN 339
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
