  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
in order to make/break the record you have to do your whoring in daylight or normal usage hours.......sitting up till 3 in the mornin when there is only 1 or 2 people online is hardly an acheivement.... right cyrus?
this is what i was told by the maxi-whores when i pulled my first record a few months ago at 3 or 4 am.....hardly counts.
Bastard :mad:
I am sooooo sunburned after the drift day. If I take my shirt off it looks like I'm wearing a big red balaclava and long red gloves :P Cyrus hit me with a bit of styrofoam before and it pulled my shirt across my neck, AAAAH!!!
