  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I realise now that the "Pope STFU" picture has a java applet in the background, that sends a signal back to "Bible Basher headquarters" so they know that some blasphemy has just happened and that the protagonists are in need of salvation
Rhad... The internet is cool...
Post it again!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
