  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
im gonna buy 1 of those industrial streght metal blade  fans that push  like 25psi/min they cool the place down! ther about $180 or sumthing from like bunnings or other selected hardware stores. (free plug) even though i dont work there.
we have them here at owrk..... damn noisy tho!
yeah yeah, u still dont get to perve on chickys in ya lounge room now do ya.  Ed G------ yeah they are noisey but il put up with it, to stop from being hot. what do u do for work anyway??
long story short.. i work for telstra in the radio and satellite area
walk 2 secs and be in 18degrees :P
i can do this 2, walk out the front and open the door turn the key and "wala" skyline 18degrees aircon! arrgh! and i really am not a beach devo. i rarely even go to the beach, i take it for granted bcoz i live so close i suppose. i love the beach though. couldnt live away from it again. (once i live in kallangur with a mate for 6 mnths throught he middle of summer, and damn it was hot, and there was no relief from the heat except go to the pub and sit in the aircon there and drink piss all day! :looney: )
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
