i couldnt help but noticed some noobies in here ...
well SkylinesAustralia is the 2nd most hit car forum in Australia, so regardless of people going off to do something else (as is their right) it was always going to find people to replace them
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hmm.. i'm still in the top ten in terms of whoretown postcounts :D
looks like it will be a long while before you will get knocked off too, maybe never if you keep this up.
I have moved into the top four, didn't notice till then.
How sad
