  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah but dc++ has been around since before napster and there aint nothing I have not been able to find yet on it. Good Warez since 1997!
Plus I'm lasy and dc++ works for me so I've never had the need to try BT, although everyone raves about it, but each to their own.
I seem to remember some stuff which I found for you easily with dc++ which you couldnt find with BT ;)
right now i have just over 2 peta bytes to search through, and its got the search integrated into the client, so now searching for torrents then adding it in.
Plus once you queue a file the client automatically searches evey 30 seconds for that exact md5 file from other users, so find the file once and watch the multiple users to download it from burst into the hundreds.
One thing I think BT has though is downloading the 1 file from multiple users at once, that is in the wish list for dc++.
Most def... DC++ has everything... But requires lots of work...
10 mins I can show you how to use it, ;) yo want me to come around there earlier tonight and show you?
You got netlimiter havent you?
Anyway c yas back to work I go!
