  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah but dc++ has been around since before napster and there aint nothing I have not been able to find yet on it. Good Warez since 1997!
Plus I'm lasy and dc++ works for me so I've never had the need to try BT, although everyone raves about it, but each to their own.
I seem to remember some stuff which I found for you easily with dc++ which you couldnt find with BT ;)
right now i have just over 2 peta bytes to search through, and its got the search integrated into the client, so now searching for torrents then adding it in.
Plus once you queue a file the client automatically searches evey 30 seconds for that exact md5 file from other users, so find the file once and watch the multiple users to download it from burst into the hundreds.
One thing I think BT has though is downloading the 1 file from multiple users at once, that is in the wish list for dc++.
Most def... DC++ has everything... But requires lots of work...
10 mins I can show you how to use it, ;) yo want me to come around there earlier tonight and show you?
You got netlimiter havent you?
Anyway c yas back to work I go!
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
