  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
As unbelievable as it may seem, I didn't actually take a camera with me. There wouldn't have been much left of it if I had - there were some people in scorched hazard suits being taken away on stretchers shortly after, and police tape everywhere. Survivors were heard muttering what sounded like "punani", but it was later translated as the far less appealing term "poonami".
As a public service, and to satisfy your morbid curiosity, I believe it would have been a combination of the "toxic waste dump" and the "porridge poo" varieties, showing signs toward the end of becoming a "fire hose".
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
