  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Meh through extensive testing I have proven that fact wrong, I eat a tad bit more when starved.
Tested on bowls of nutrigrain, didnt eat for 24 hour period, well actually didnt injest anything, no water, not nothing for 24 hours. After I was able to eat 3 full bowls of raw nutrigrain, (adding milk could bum up results as it makes the nutrigran expand). After snacking lightly for 24 hours could only eat 2.5.
That whole stomach shriveling thing might be true, but time after time it has proven wrong for me :rofl:
Scanners Cyrus??
In all honesty I haven't even looked at any computer hardware specs prices since I left Umart, after almost three years I had enuff of that stuff.
Ummm probably Epson or Canon though
Hey do u want a lift in? Iopia has to drive right past your place, also 33NIZ lives down your way?
You know you want that feeling of a hot poker shuved up your ass when trying to empty your bowels!!!!!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
