  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Sexus, oh sorry, Nexus, do you work from home, or for a business/company as an employee?
I manage the Gold Coast branch of an online computer hardware business by the name of Umart Online
www.umart.com.au
(Shameless plug)
I manage an online computer hardware business by the name of Umart Online
(Shameless plug)
Umart ?!? ... shit ... in a good way of course ... that's where i got ALL my PC components man... from Milton Branch.... price and service is fantastic !!
Cool Glenn,
I run the Gold Coast branch :D
he had the baggy blue shorts, and brown t-shirt. I remember, because we were going "mindflux and his crazy boot, who is that guy?" and he was standing right there .. lol :D
You sucks :D Also you might see me working down there soon (at the goldcoast store). I'm starting monday... thanx to that Great Guy Nexus9 (lol.. here is me sucking now.. haha)
dum dum dum~~ another one bites the dust~~ :D
pred - you are IT also ?
Yep.. i think a large number of people on SAU are actually. I actually did a bachelor of Applied Science in Multimedia technology, but these days I'm not too fussed what I do -- but computers are a lot more interesting that some things.
Most of the people in VIC worked in computer related areas in one way or another :D
I can see it all now Computer workshop out back
Skyline workshop out front
My two loves all in one neat package
haha, yer :D In melb, about 4 of the guys work at iPrimus and have their skylines all out the back.
reading cnn huh.. the real world? you don't wanna read about that! too depressing! :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
