  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
/looks around.. did somebody mention *beer* ?? :D
yeah, while its tempting to take the cheaper option. I think its probably a good idea in this case to get it repaired professionally, it is your steering afterall and an important part of the safety, etc of the car.
If you can track down a 2nd hand control arm, would you be able to just replace the bushes?? They are just rubber doova-hickeys aren't they?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
