  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol, could anyone else have had a door ripped off pred style? ok maybe Lol
haha.. true.. only me ! one in a million thing.. even at the time i was thinking "this can't be true.. am i dreaming?!" My door was one second ago perfect.. now its at right angles.
and my window, and that tint that I was really annoyed about that scratch only a few minutes before was lying 20metres down the road in a sticky blob on the ground.
nizmo - i think ill just get my mate to make one up off photos..
what more can i do.. its IMPOSSIBLE to be unique thease days :)
Ca18det conversion, with 2lt stroker and twin td06's.. thats different and hasnt been done :) kinda not really a skyline if it had a silvia motor in it then i spose.
Although there is a R33 with "light tune" Sr20det up for auction atm, which has catched my eye...
haha i just read this joke
First-year students at Med School were receiving their first anatomy class with a real dead human body. They all gathered around the surgery table with the body covered with a white sheet. The professor began the lecture by telling them: "In medicine, it is necessary to possess two important qualities as a doctor "The first is that you not be disgusted by anything involving the human body".
To illustrate, he pulled back the sheet, stuck his finger in the anus of the corpse, withdrew it, and stuck it in his mouth. "Go ahead and do the same thing," he told his students. The students freaked out, hesitated for several minutes, but eventually took turns sticking a finger in the butt of the dead body and sucking on it.
When everyone finished, the professor looked at them and said, "The second most important quality is observation." "I stuck in my middle finger and sucked on my index finger. Now learn to pay attention!"
this will make u think
Once upon a time in China, lived two Chinamen. One named I cum and one named No cum. No cum marry pretty Chinese girl named No cum tu. For velly obvious reason No cum and No cum tu not have any children. One day, No cum went out of town on business and I cum came over and spent the night with No cum tu. That night I cum came and No cum tu came too. This make both very happy. However about 7 or 8 months later, No cum see he about to become father but he not know how come, so when baby come, he named it, How cum u cum. Of course, I cum and No cum tu know How cum u cum came but to this day No cum not know how come How cum u cum came!
Cum again?
hey umart boys,
i have been purchasing ALL my PC gear from umart in brissy for years (ever since Computer Alliance fully ripped me off, called me a liar and left me pc less for 6 weeks)
im about to buy some gear for a mate who lives down the coast, but i was gonna put the order through up here
any chance u boys could give a fellow liner owner some sort of a discount if i put it through the coasty store?!??!?!?!
that would be tops
i buy computer gear all the time :)
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
