  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey they ultimate nerd accessory for your car..
"Unreal Tournament 2004 DVD Special Edition" will come in a limited edition metal box and will contain a Logitech Internet Chat Headset for use with the game's exclusive voice-over-IP (voice chat) technology, as well as an Unreal window sticker.
lol...you lazy bastard
I gotta stop drinking large quantities of Coke late at night....had the worst nights sleep
haha... i specially planned my week so that i get thursdays and fridays morning off, mostly becos of the cruise.
drink h2o like me!! :D
I can't believe that you got up after 11 glenn.  I had the worst nights sleep and I had to be up by seven.
actually, james, i can stay in bed till arvo but my dog was whining at me becos it had to go outside really bad for ya-noe-wat....
why is everyone having such terrible sleep last nite??
Just crawled out of bed myself. I did get up at eight though, didn't bother going to work today cause of the impending weather, so got up went to gym, came home and went back too sleep. Only got woken up by a delivery guy, he had my nismo clear indicators for the GTR. If only all days could be like this.
I couldn't sleep because my matress is on the floor with all the dust, (which I am highly allergic to) because I moved the base and the rest of my stuff to my new bedroom but can't sleep in there because the paint fumes are yet to clear. Should be good this weekend though.
