  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
is it work at home or office? i was at the milton Umart this arvo picking up the LCD and it was PACKED.
i reckon that it being on the table top the best. you can move it anyway you want and it takes up so little space.
i wanna get the 19inch next :)
nope.. flatmate owns the house and gets to park (wait for it.. ) his 80's camry in the garage.. therefore mine stays in the street.
Not too happy about it, but not much I can do .. 'xcept move :) thats the next possibility - I need a garage for other crap anyhow.. so soonish
yeah.. i been into milton to pickup my speakers.. was way busy. Goldcoast is a lot less chaotic.
I've only got a CRT atm, but my old work I used one occasionally and loved it. 19" LCD at the moment are bit pricey, but in 12 months they'll be pretty much at the level that 17" are now.
err.. milton.. its on the website: 28 Douglas St, Milton. Near the brewery.. actually what am I talking about its like right around the corner from your work :)
I think its the first right turn after maccas then you gotta turn into douglas st. . Only been there once so i forget.
im off to umart this morning to pick up my goodies
building a system for a mate
off to the computer markets tomorrow to get teh stuff i dont need to get new (monitor/keyboard/mouse)
i love umart, awesome prices, good gear, never had a scrap of drama with the brissyh mob!
What a load of shit my weekend is..
I had been hanging out for the weekend like no tomorrow .. and iw as excited because i was planning to take the 32 our, and hopefully meet some people .. as this guy i know was having a partyy..
getting all excited the weekend come, i read my star sign (yeah my ex got my hooked on that stuff, tryin to kick it) and all week it was sayign stuff like your going to meet a lovely ladie, roses are blooming yadd yadda yadda...
well considering my VERY messy break up and how shit things have been ever since ive moved up here .. i was excited that i was finally going to get a break.
i started putting the backseat in my car and hear my stomich winge to me .. so i solider on
and my head startes to playing some very loud bass.. not been able to take much more i went in to lay down on my back which feels like its been run over 50 times..
i slept for about 15 hours on and off .. and here i find myself, having to stay home as im sick as dog..
how typical ...
i swear someone has a hex or a voodoo doll out on me :)
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
