I'm a tightass so use the Mobil1 SemiS stuff. Seems fine, seeing as i'm pretty hardcore on the changes on every 5k -- bit expensive $55 or so each time for the full synthetic.
SemiS is usually only $32 or so.. It does say "designed for turbo charged engines". Probably not as good for the engine as fully synthetic but my engine is still running strongly.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Guys .. i need some help..
when need to start a 'find flux a friend' campeign or something .. because im so over being a loner..
im thinking of moving back to sydney because its just not happening up here..
so please feel free to donate a human to this fund preferable female aged between 18 - 25 with out any ****in mental issues ;)
please?
ill be your best friend!!
Nah i just think it is the way the light fell, here is a bigger picture... http://www.skylinesaustralia.com/photopost...&sort=1&cat=500
The Front bar now that is a different story, that is badly in need of respraying at the moment, I want to do it but I also have another veilside front bar to go on when I get the FMIC, so I don't want to get it sprayed if I am getting it replaced soon, but I am hating they way it is at the moment too.
Hmmm decisions, decisions ;)
I don't know yet,
I was thinking of keeping it "just in case" but I don't know if I want a front bar hanging around the back of the house indefinitely.
I guess I will decide when the time comes.
Why? are you interested in it?
I feel for you mindflux,
when I first left highschool I went and lived in Europe for a year by myself, man there were some lonely times there at the beginning.... but you stick with it and it comes good eventually.
Just have to have faith in yourself that you are a good person and that you have something to offer I guess.
doesn't make it easy though ;)
A female of any age without ****in mental issues is a huge ask nowadays
I blame it on reality TV ;)
now mindflux: don't go killing anybody now will you?
I should go down to DMD and pick up my sideskirts, nice day for it!
Mindflux, you sound like patrick batemen. Go and read Some Brett Easton Ellis and if you understand it on any level be very worried. and you really have to stop caring so much. Also if you're all jaded on relationships this might help clarify how women's minds work. Sorry if it's a repeat.
www.laddertheory.com
and remember if you see a guy who is clearly a dud with a really really hot girlfriend don't envy him. Pity him.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
